Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 36
Thread: Complete Shutdown
  1. #21
    Marietta GA
    Quote Originally Posted by Shayne Jenkins View Post
    Packet ET is between 15 and 19.
    I do not see any error logs in the event viewer.
    Hmmm... as far as I know, there’s no way for the control box to tell the SB3 software to shut down.
    Just losing Comm would result in an alert box that gives you the opportunity to retry communication or proceed in demo mode.
  2. #22
    windsor boat works limited, gravenhurst ontario
    I had a similar problem once wit my older machine . I could air cut the file no problem , but as soon as I started cutting the static would somehow back feed through the electrical ground and mess up my computer . I eventually ran an isolated ground to the Shopbot that wasn't common to the computers ground and the problem stopped
  3. #23
    Jul 2005
    Brookline, New Hampshire
    "I do have excess motor cable looped under the table" If it is all coiled in one direction, it forms an inductor (coil). It would only be a micro henry or so but still a coil. if you take half of the coil, flip it 180 degrees, and lay it on top of the other half, the halves cancel out each other. Per your description of your problem, I don't think a coil is your problem but it would still be good practice to eliminate it as a source of problems.
    Be sure that your data and power wiring are as far away from each other as practical avoiding mutual inductance.
    I would also recommend that you get a cheap AM pocket radio (with an earphone). Yeah, I know this sounds like a joke; It isn't. Tune the radio to part of the band where you don't hear any station. You now have an extremely sensitive RF sensor. If you experiment with it some, you'll find that the H Field (magnetic) antenna is highly directional.
    If you have an intermittent power connection you'll be able to here it and locate it by moving the radio around. If you use a single to three phase inverter, you are likely to hear that as well and will soon be able to determine normal operation.
    The radio will also detect static discharges as an audio "snap". You might want to record the audio. If the recording captures a "snap" and everything shuts down, you know what to look for.
    I have used this technique to debug an avionics computer. It served as another modality of detecting abnormal operation.
    The technique has also been used to detect the operation of electrical welders and plasma cutters at considerable distance even when there were no other indicators.
    Paul Z
  4. #24
    Nov 2011
    Akron, OH
    Quote Originally Posted by robtown View Post
    I have tried hitting the E-Stop and sometimes the software shuts down there also. This leads me to believe the box or software is seeing the E-Stop is being pressed. The E-Stop is mounted on a small wood platform that I have tried shaking without triggering the stop so do not believe that it is a loose wire or faulty stop.
  5. #25
    Nov 2011
    Akron, OH
    I want to ask something that may seam obvious. Everything in the box is ground to the ground rod in the box and the box is mounted to the frame. All of this should run back to the AC power, right? So it should already be grounded back to the circuit breaker. I just want to be sure that if I am adding a ground it serves a purpose and does not make things worse.
  6. #26
    Nov 2011
    Akron, OH
    Quote Originally Posted by paul_z View Post
    Paul Z
    This technique sounds like too much fun to not try even if I can solve this issue without it!
  7. #27
    Jan 2008
    Ahh, now we're havin' some fun! Your my kind of CNC'r!
    It's kinda like MY: If there ain't no blood, it can't possibly work!
    I seriously hope you find it though, I just hate intermittent issues, they just suck! Russ
    AKA: Da Train Guy
  8. #28
    Dec 2011
    Piedmont, SD
    My previous set up was exactly as you describe, PLUS I had a dedicated 6-8 gauge ground wire on leg of the shopbot's frame. I had lost communication issues regularly at this time of year.
    New Building, same setup, but the box is on the wall, no longer in contact with CNC frame. One year solid, no comms issues.
    I know you're not getting lost comm's message, but still appears static related.
    Key point here is the ground should look like branches on a tree as it terminates at every electronic device involved with running your cnc. If at any time two branches connect to each other, in this case the cnc frame and control box, trouble can arise, as that static charge (about 10,000V) may be inclined to travel through the control system vs. straight to ground. It's confusing, as you could run for months like this with no issue, but this is the time of year when atmosphere is dry, plus the fact you're cutting PVC means you're likely generating far more static than those of us who have fought this cutting strictly wood products.
    With your current setup as described, a static charge has the opportunity to jump back through the control box as it travels to ground. By isolating the frame, static discharge will have a path straight to your main building ground, vs through the delicate controls.
    Yes, it all goes to the same place, but best to give it a path that completely bypasses your control box and control computer connections. Electricity, like water, flows, and it will take the path of least resistance, so consider that chassis grounding cable as a first line of defense "trench" to dump unwanted charges to the ground vs. spilling over and "soaking" the sensitive controls.
    I would suggest removing the control box from the frame - set it on some 2x material on the floor temporarily. Connect a dedicated ground cable from the cnc table leg to your main ground. See if this separation of grounding paths alleviates the issue.
    Cheap, fast, easy test.
    Jeff
  9. #29
    Just remembered a time when SB3 was totally kicked off.....it was a panic situation when I first started...and hit the Spacebar for a Pause like crazy.
    Sb3 just dropped off the screen and had to do an E-stop.
    Reoccurred when we had a "sticky" spacebar once also.
    Found the thread where Ted Hall explained that they were fooling around with multiple/fast Spacebar hits(5?) would shut down SB3.
    See hi lighted section of thread below.
    Probably not pertinent now as it was so long ago, but have you swapped out keyboard and mouse just in case, and one of them IS "Sticky", and that feature is still active in your version?
    Just mentioning.
    Nov 2011
    Akron, OH
    Thanks again guys. Jeff's suggestions are giving me some confidence in grounding properly. Will report back soon.
    Shayne
