How do I go about drawing a dado for most efficient cutting? It is not looking very efficient:
No luck locating the bone filleting option...
The help file in PartWorks is excellent - you can find the dogbone option under the filet tool. First, draw a rectangle, then add the dogbone.
Most dados are done with a rectangle and a pocket toolpath. Make it at least 1X bit diameter longer than it needs to be past the edge (1/2 bit dia per side) if you want to carry the dado from edge to edge on a panel.
